Need Upper Control Arm Bolt
Trying to get this thing aligned finally, replaced the brand new duralasts ball joints with Moog and solved that issue. Now I have another issue, the drivers side front upper control arm bolt is fried, bolt is spinning inside the washer not allowing the shop to adjust it. Where can I get just the bolt, nut, and washers? I tried gmpartsdirect.com but dont see a listing just for the bolts.
96 4x4
96 4x4
RE: Need Upper Control Arm Bolt
Anyone????
Short of a dealership with the appropriate parts catalogs or just nabbing one out of a junkyard, I doubt you will find the exact bolt in the aftermarket.
Hopefully that works for you. Looks like they just milled down a standard bolt though...
I really just need the washers anyway, mineare rounded out and the bolt just spins. They seem to be a pretty reputable outfit, they make all kinds of stuff and I found them at many different import performance websites.
Thanks for all your help, this site is the best.
ryanleh
09-03-2011 08:46 AM
cage47
06-11-2010 12:17 PM
