New Brakes --> follow Haynes?
Old May 11, 2011 | 11:53 PM
Jonboy's Avatar
Jonboy is on a distinguished road
Default New Brakes --> follow Haynes?
I've never done brakes on an ABS system before, though I've done plenty on older cars with no issue. I looked in the DIY section, an didn't see anything....
Should I follow what is in my Haynes manual to replace them (I need new rotors too), or is there a good online article somewhere on here?
Or should I pay someone else to do them?
Thanks,
Old May 12, 2011 | 11:13 PM
rodono's Avatar
rodono is on a distinguished road
when changing the brakes you will not noitice the ABS system the sensor is on the wheel hub and not the disc. but yeah why not use the haynes if you got it. i have one and use it as a good refrence book.
Old May 15, 2011 | 02:19 AM
84BlazerS10's Avatar
Yeah, there isn't really much difference when it comes to changing ones with ABS from my experience just sometimes you have to bleed the brakes a bit differently.
Old May 15, 2011 | 09:00 AM
leeroy74's Avatar
leeroy74 is on a distinguished road
There is no difference with an abs brake job. Just take your time and have fun saving money and doing it yourself. There are also youtube videos on blazer brake jobs that helped me!
Old May 16, 2011 | 06:45 AM
TZFBird's Avatar
TZFBird is on a distinguished road
I have heard that when you compress the caliper to install new pads, you should open the bleeder to let fluid out instead of forcing it back to the reservuior. This will prevent contaminated/dirty fluid from being pushed back into the ABS valves. Just in case there is a bit of rust from a line that could clog a valve.
That is the only thing I do differently than on a non-ABS vehicle.
Old May 16, 2011 | 08:03 AM
GunsOfNavarone's Avatar
GunsOfNavarone is on a distinguished road
Brakes on your vehicle are very easy. One thing to keep in mind is that if doing the rear brakes, you likely will need to replace the calipers, they typically seize after the rear brake pads are replaced. Save yourself the trouble of doing the job twice, consider loaded calipers for the rear brakes.
Old May 16, 2011 | 08:49 AM
I would recommend this on all vehicles, not just ABS equiped vehicles. Contamination can damage the seals in the master cylinder as well.
williamapocalypse
Sep 17, 2012 10:01 PM
chris015
Aug 3, 2011 08:17 PM
Sturg
Dec 13, 2010 11:15 AM
BonestockZR2
Nov 2, 2009 07:00 PM
kiwiblazer
Oct 14, 2008 12:02 AM
