New engine.... Now what???
I have been reading for the last week or so and I can’t find any thing on this, so now its time for me to ask you guys! I have a 2002 blazer 4 door, 4 wheel drive and I blew the motor in it! I got an engine out of a junk yard with about 70,000 miles on it. I stripped it and completely rebuilt it. After I got it all painted up and installed it, it seems that something isn’t right! It runs great but some times it’s hard to start! Kind of like the timing is out. And I am getting horrible gas mileage! Like 10mph a gal! Yikes! I took a scanner to the com and every thing checked ok, except the code for cam and crank correlation. I tried to do a relearn and it wouldn’t work??? I think I need a new scanner! ???? I don’t get it! So what do you guys think I should do??? It runs great, but like I said it’s hard to start maybe 50% of the times and the fuel mileage is horrible. And also if this helps the exhaust smell different... and I can’t put my finger on it, but it smell different! And I have noticed a lot of water (moisture, condensation) coming from the exhaust tip! So if you can let me know what you guys think! Thanks for you time
r/Mike
r/Mike
yup....
its that code! P1345. i tried to do the relearn and it didnt work.... the scanner never went to the next step???? so beats me! i guess i have to try a different scanner~! can this code make that big of a difference? with the fuel and all???? also its def not a bad cat! it doesnt smell like sulfur or anything.... it almost smells like its running lean???? kind of like a metal smell.... but i think its only when i first start it wile the car is in choke mode!!!!......
Another possibility is your distributor or timing chain is a tooth off. Did you check out the tech article for the code? If your scanner can show cam retard info it'd be helpful.
hmmm......
i didnt check my what my timing was wile i was running it! the scanner did say i was good to drive! lol.... but i know 100% that i am good with my timing gears and chain. and i know my distributor is in at top dead... like i said the blazer runs great, but sometimes it seems like its hard to start. as if it were like the timing is way out... like it will crank crank crank... stop...... then crank crank crank and then fire! ??????????
Meanagersmom
06-13-2010 11:33 PM
91s-10blazer
09-01-2009 03:50 PM
