new fuel pump still want start PLEASE HELP
Old Sep 3, 2011 | 01:23 PM
bromanjr's Avatar
bromanjr is on a distinguished road
Originally Posted by delete242001
got a 1997 chevy blazer 4.3 v6 auto 4 door ran great had tune up in the last year im getting spark from coil i get gas all the way to the motor but after that nothing.it will start for a second run then dies. if i take fuel lines loose over carb there is gas but it will only run if i keep spraying gas in the carb.i got no check engin light i put fuel pump in last night nothing.when it would not start the motor looked like it was moving more than usual.after i put fuel pump in the motor doesnt shake as bad now but will only start for a second.i got nothing i have no idea what it could be any sugestions please help i drive 30 miles one way to work and this is my only car
If you are "spraying gas" in the "carb"(Throttle Body) then you probably have the intake tubing disconnected. The intake tubing must be installed for the engine to run. The MAF is mounted in the tubing near the air filter box and must be connected to engine.
You should use a gauge for the fuel pressure on the fitting behind Throttle Body to test and read proper pressure.
Old Sep 3, 2011 | 04:16 PM
Tobashadow's Avatar
Tobashadow is on a distinguished road
Don't rule out crank sensor, had a 92 do the exact same symptoms.
BouncingRadical
14
Nov 27, 2015 12:30 AM
bobby01
Oct 30, 2014 07:36 PM
hypertek
26
Mar 3, 2013 04:58 PM
davtak
Jun 28, 2011 08:47 PM
rogggg1020
Nov 11, 2008 08:05 AM
