new here with an exhaust question
Old Aug 1, 2012 | 12:28 PM
dunnboy's Avatar
dunnboy is on a distinguished road
Default new here with an exhaust question
Today I was driving and heard what sounded like an exhaust leak. I lost some power to the vehicle which I heard was normal if the exhaust were to leak. When I got home I turned the truck off and popped the hood. I noticed some smoke coming off the part in the picture I've posted and can't figure out what it is or if it is my problem. If you have any ideas please let me know. The truck is an 02 blazer. Thank you for your time and any help is much appreciated.
Attached Thumbnails new here with an exhaust question-2012-08-01_13-13-23_271.jpg
Old Aug 1, 2012 | 05:18 PM
step66's Avatar
Do a search on this site:it will lead you to the problem. This is part of the EGR system and any fault will result in exhaust noise and power loss,you most likely have an SES light as well,yes? Do your research. Best wishes.
Old Aug 2, 2012 | 03:24 AM
dunnboy's Avatar
Shockingly enough no engine light is on, but thanks for the lead it's much appreciated.
Old Aug 2, 2012 | 03:27 AM
dunnboy's Avatar
It was actually the rubber hose that comes off of that. It had a hole in it.now trying to figure out why GM put rubber on a part that gets hot.
Old Aug 2, 2012 | 09:37 AM
red 2002 zr2's Avatar
red 2002 zr2 is on a distinguished road
that is in fact the one way check valve for the emmisions air pump, the point of it is it is supposed to let air into the exhaust, but no exhaust into the air... if that makes sense to you. if you get exhaust into the air pump it will lock up and... lets just say thats bad. being that you blew the rubber hose off of it and now it is leaking exhaust it's no longer a check valve and needs to be replaced. there is rubber on the one side because it is not deigned to get hot or to flow exhaust, it is only designed to flow air until after the valve.
Old Nov 9, 2012 | 09:40 AM
dunnboy's Avatar
Ok so say I were to get the hole plugged I.e. welded would that hurt the truck any?
Old Nov 9, 2012 | 11:59 AM
Diaita's Avatar
cheap part, probably best to just replace it. .02
NAPA AUTO PARTS
Old Nov 10, 2012 | 08:07 AM
dunnboy's Avatar
I've tried getting it off it's not budging any I've soaked it in pb and put the wrenches on and nothing .
Old Nov 10, 2012 | 10:19 AM
1sttimejimmyowner's Avatar
1sttimejimmyowner is on a distinguished road
Welcome to my world LOL.There isnt dam thing on a my jimmy thats easy to take off or reinstall..I have ran into issues with tight bolts used map gas on them and they still wont come off.I have a stuck o2 sensor tryed everythingPB blaster,heat,pipe wrench cheater pipe then its rips out half the threads.
Zr2.1
Apr 27, 2013 12:32 AM
phatso_99blaz
Headers, Intake, & Exhaust
Apr 8, 2013 03:16 PM
tomdavis746
Jul 13, 2011 07:38 PM
TrailBlazer
Jul 17, 2008 12:59 AM
qquake2k
Dec 30, 2007 12:26 AM
