New ignition lock cylinder won't turn past on. Key not stuck.
Old Mar 23, 2024 | 04:29 PM
Shaolingr's Avatar
Shaolingr is on a distinguished road
Default New ignition lock cylinder won't turn past on. Key not stuck.
New ignition lock cylinder was installed and it was a bitch to change being that I did not have a key.
​​​​​​The two little springy pins that are on the ignition switch that hold the cylinder are stuck in the depressed position.
Would this be the reason that my key turns back and forth but will not turn to the crank position?
If so, how do I get the pins to be unstuck.
The two springy pins I'm referring to are the ones that you typically have to press down to turn the key they're on either side of the cylinder housing
Also, this random connector is broken... what is it and how can I purchase the connector?
Alex Eberhart
May 12, 2019 08:48 PM
MetalMan390
Jan 21, 2011 10:27 PM
MetalMan390
Jun 8, 2010 02:27 PM
97ssblazer
Sep 2, 2009 01:08 AM
Smoked
Feb 21, 2009 03:20 PM
