new knuckle or...?
Old Aug 22, 2008 | 11:12 AM
95LS's Avatar
95LS is an unknown quantity at this point
Default new knuckle or...?
i just did a brake job on the truck ( new rotors and pads on the front and shoes on the back ) when i was putting on the calper bolts on the front left side the lower bolt was stripped (not the bolt itself but the knuckle) unless i can find a helicoil i think im gonna need a new knuckle. anyone have any suggestions ? im thinking if i find a helicoil im gonna have to get a diffrent bolt to work on it and i dont know how easy that would be to find. worst case could i use a regular shoulder bolt ?
Old Aug 22, 2008 | 12:31 PM
WolfPack's Avatar
Default RE: new knuckle or...?
If I recall...don't the caliper bolts have a slight taper to them at the threads? That would make them a bit different from a normal shoulder bolt. But if youre helicoli-ing...man I dunno..
Some online searching has pointed out a few things. First, the helicoli could be a problem with the intense heat of the braking system. A couple threads were concerned with the rates the different metals will expand under those temps. Second, do you really wanna leave your braking up to a little helicoil?
The calipers are going for like 30-50 bucks on ebay.
Old Aug 22, 2008 | 01:37 PM
No taper to the threads.
The purpose of a helicoil is to create threads that match what was originally there. I don't know as I would trust them in that location though. Not necessarily due to heat, but due to vibration and just general discomfort for doing something like that to such a critical system.
I would try to find a new steering upright at the junkyard. Should be fairly cheap.
Old Aug 25, 2008 | 05:33 PM
95LS's Avatar
i found one for $75 at a local junk yard. ive heared of people helicoiling spark plugs but nothing major like this. i dont know how easy it would be to get a drill in to take out the rivets on the ball joints and i know you can rent tie rod and ball joint seperators. so doing it myself wouldnt be a problem. i may as well do all new ball joints,tie rods, and bearings since the truck has 150K miles on it and possibaly cv shafts/axle/ whatever you want to call it.but i have never helicoiled anything and i dont knwo how reailable they are.
Old Nov 4, 2008 | 05:16 AM
ja8404's Avatar
ja8404 is an unknown quantity at this point
There is a oversized caliper bolt that will bolt right in. It has a thread tap on the first half the threads to make its way in. I had the same problem with mine and aked a buddy who owns a break shop and he hooked me up. The bolt also has a cotter pin that goes into the end of the oversized bolt because of that lawsuit ****. I have one in mine and its working like a charm. I picked it up at my local Napa store. Just ask its only 20 dollars and it'll take about 15-20 minutes to work in...
Old Mar 22, 2009 | 08:27 PM
raysnevascared's Avatar
raysnevascared is on a distinguished road
I am having the same problem with mine ... When I go to Napa what exactly do I ask them for ??
stiggybaby
Jun 11, 2012 08:53 PM
Curt8153
Nov 17, 2011 06:30 AM
dabone86
Feb 2, 2011 10:09 AM
marklar
Aug 2, 2010 11:04 PM
whitejimmy
Feb 19, 2010 09:51 PM
