new to the site and having issues with my zr2
Old Mar 11, 2014 | 11:39 AM
ckawi1986's Avatar
ckawi1986 is on a distinguished road
Default new to the site and having issues with my zr2
hey blazer forum, im having issues with my zr2 and figured what better place to see about getting some ideas then here. i have a 2000 zr2 that my father did a motor swap on a while back and now its mine. my issue is that i now have a few lights on on the dash and the scanner just keeps reading error when i hook it up. The check engine light, abs light, battery light, and brake light are on on the dash. The ALDL looks fine and is connected. i dont know where to start under the hood or anything. can anyone offer some advice or tips???? Thanks alot
Old Mar 12, 2014 | 12:34 AM
justaguywithtools's Avatar
justaguywithtools is on a distinguished road
a communication error could be because the dlc fuse is blown, if you have a test light check for power at pin16 all the time. if not check your fuses. it could be the acc fuse or the cigar fuse depending on the model.
Old Mar 12, 2014 | 07:17 AM
LannyL81's Avatar
Did your father do a complete motor swap? Was the ECM changed-out as well? If not, was the ECM re-programmed for the new engine? I think at least the ECM will need to be run through the re-learn procedure....do a search and you will find the details.
jezzika39
Aug 21, 2012 01:15 AM
Idaho Mike
Apr 5, 2010 06:22 AM
M. Lowes
Jun 30, 2009 05:45 PM
exarkun1178
Apr 15, 2008 07:53 PM
CodyT
Feb 15, 2008 04:40 AM
