New transfer case shift motor???
So I need a new shift motor because mine is appearantly to weak to engage my front axle?? Mine has the 4 buttons with the auto 4wd button. Do i need a particular one or just one that matched my year?? I was looking to get a new one offline for 140$ any help please??
![](http://static.am-autoparts.com/images/button-i-want-it-big.gif)
Availability: In Stock, Ships Within 1 Business Day
AM Autoparts Price: $138.50
Year Range: 1998 - 2001
FREE SHIPPING AND HANDLING!
Specifications:
Specifications:
- NEW CHEVY / GMC / OLDS SUV TRANSFER CASE SHIFT MOTOR!
- 2 Pin Rectangle Connector
- Fits model 136/236/246 transfer cases with NP4 code
- Replaces Dealer Part Number: 12474041
- 1999 2000 2001 2002 2003 2004 Chevy Astro
- 1998 1999 2000 2001 Chevy S10 Blazer
- 1998 1999 2000 2001 Chevy S10 Truck
- 1998 1999 2000 2001 GMC S15 Truck
- 1998 1999 2000 2001 GMC S15 Jimmy
- 1998 1999 2000 2001 GMC S15 Sonoma
- 1998 1999 2000 2001 Oldsmobile Bravada
Last edited by swartlkk; 09-12-2010 at 02:56 PM. Reason: *Consecutive Posts* - Please use the edit feature to add more information to your post if another member has yet to reply.
The encoder motor only shifts the transfer case, it does not engage the axle shaft. There is a vacuum actuator under the battery that operates a clutch mechanism that engages the right front axle shaft to the differential output shaft. Select 4WD, engine at idle, there should be manifold vacuum at the actuator and the cable should pull in about 3/4". What year is the vehicle? What model transfer case do you have? On the rear of the case there is a round tag with the model number on it.
Flyfishen
06-18-2019 11:22 AM
PsychoGMRS
04-10-2019 07:08 PM
ChrisNick78
11-25-2012 08:09 PM
doodad69
11-29-2008 03:25 PM
walkingtall
05-26-2008 07:12 PM
