Newbie first post- where can I find RHD ignition switch?
Hi all, new member from down under here.
I have a 2000 rhd blazer looking for an ignition lock barrel I have found that they are like hens teeth any advice or help would be greatly appreciated thanks
This is what im after except the bit that goes into the switch is in the middle and i need one that is off to the side. Just so im being clear my vechile is rhd,auto and the shifter is on the floor not on the column if that makes a difference.
I'm browsing a Rock Auto website just advised here. Probably You may get the part at a decent price:
https://www.rockauto.com/en/catalog/...cylinder,10041
Welcome!
When looking for parts, I'll sometimes check the part numbers to see if they are the same or not. The US GM parts web sites are normally pretty good for that. You might find that the RHD and LHD lock cylinders parts are the same.
no they are different as I have described
I'd try looking into rockauto and compare to the same year of GM's different models.
Try looking for U.S. or Canada built cars. Once you figure out which cars used the same steering locks you may be able to broaden the search in the U.K. to find a spare or pick one in a scrap-yard.
Dobe Rottie Gang
08-29-2013 06:14 AM
Jonas
09-25-2012 07:47 PM
