no brake lights
Old May 13, 2009 | 07:44 AM
jon66's Avatar
jon66 is an unknown quantity at this point
Question no brake lights
Ok guys I need some help .my break lights quit working .
all of the bulbs are good the fuse is good and the roof mounted light works.
but the tail light breaks do not .flasher work park lights work.
so I am at pulling my hair out .
also I do not know if this has any thing to do with one another I just noticed
that my emergency flashers are not working also so WTF is going on
PLEASE HELP!!!!!!!!!!!!!!!!!!!!!!!!!!!
Its a 2001
Old May 13, 2009 | 08:00 AM
Sounds like a problem with the hazard switch if not the whole multifunction switch. This is quite common. Are your turn signals affected as well?
A few threads for your reading pleasure:
Broken Hazard Switch Repair
98+ Hazard Switch Replacement <--book method which has you do quite a bit more work...
Old May 13, 2009 | 08:18 AM
jon66's Avatar
no my turn signals work fine
Old May 13, 2009 | 10:53 AM
Ok, go through the posted referenced above. The multifunction switch is responsible for those functions. You either have a problem with the hazard switch (likely) or the multifunction switch. Try messing with the hazard switch to see if you can make it work.
Your brake switch is obviously working since your 3rd brake light is working properly.
Old May 14, 2009 | 12:43 PM
jon66's Avatar
I messed with the hazard switch and the brake lights are working .
at least I know what direction to go in now .
thanks for your help swartlkk you saved me a lot of time and pain
Old May 14, 2009 | 02:21 PM
Good deal! Glad to help!
edavison
Dec 20, 2010 09:55 PM
step66
Oct 14, 2010 04:52 PM
SCBlazer96
Apr 16, 2010 08:39 PM
dashyman
Jan 12, 2007 11:28 AM
rryker
Apr 25, 2006 04:14 PM
