no heat...
Old Nov 11, 2006 | 05:38 AM
elementx440's Avatar
elementx440 is an unknown quantity at this point
Default no heat...
Ok so I've researched this problem and it seems to be pretty common.
I get a little warmth at the beginning, then it cools off to outside air temperature. This afternoon I put a new thermostat it, then I flushed the coolant with one of those prestone flush kits where you put a garden hose on the intake.
Anyway, one line going to the heater core gets hot, the other is slightly warm. Do I have to flush the heater core seperately? Since the thermostat will never open with the garden hose method?
Is there a way to purge air out of the system? Or will the pump shoot it out and take care of it somehow? I can squish the core hoses with my fingers, should there be any pressure on the hoses?
The reservoir and radiator itself are cool to the touch. The block gets nice n hot. The temp hovers around 180... could the thermostat just not be opening yet? I think its a stock 195 degree.
The engine runs at decent low temperature, so that means the water pump is fine right? Maybe my core is clogged, I'm gonna flush it tomorrow morning but if anyone wants to chime in feel free.
Old Nov 11, 2006 | 10:34 PM
Chevy Lover's Avatar
Default RE: no heat...
Both of your heater hoses should be the same temperature. If they're not, it's because the coolant is not flowing through the heater core. You can flush the heater core by itself.
If your coolant is low in the radiator, run the engine with the rad cap off, til the coolant level drops ( that means the thermostat has opened), then top up the rad coolant level and install the cap.
Old Nov 12, 2006 | 02:52 AM
Thanks for the reply.
Early this morning I disconnected the heater core, connected one hose to a garden hose, and the other to a drain basin. I used clamps to make a nice pressure tight connection and cranked the garden hose up. Some awful gunk shot out of it then th water went clear. I made sure to swith the hoses and flush the other way, and sure enough more nasty stuff came out. I hooked it all back up and now we got some heat!
Old Nov 12, 2006 | 04:37 AM
4lowlife's Avatar
Good job! IT should self purge.
Old Nov 12, 2006 | 10:02 PM
Good job man! Glad it was as easy as a simple flush!
Old Nov 1, 2007 | 03:42 PM
97z2801ss's Avatar
97z2801ss is an unknown quantity at this point
hey guys im tony. I have a 97 Blazer 4x4 and a 97 z28. I just replaced the tstat in the truck and its still blowing cold air.
I havent had the coolant flushed in a few years but its my winter vehicle/DD the coolant is a dark orange looking color. Its full im just not sure if i should flush it again or what todo? I have a child so he needs to be warm in the winter.
Old Nov 1, 2007 | 03:48 PM
Burlisonm's Avatar
Burlisonm is an unknown quantity at this point
The system should be flushed every 2 years or 24,000 miles, so if its been a little bit that would be the first thing that I would do.
Old Nov 1, 2007 | 05:03 PM
97z2801ss's Avatar
thanks for the responce, if flushin out the heater core doesnt work, I guess thats what ill have to do.
Old Nov 8, 2007 | 10:56 PM
KIllarb634's Avatar
KIllarb634 is an unknown quantity at this point
Had same problem, Flushed heater core this morning and very little amounts of debris came out, however heat works wonderfully now. Also changed tstat since the motor was taking forever to warm up. now warms up quicker and heat works.
CSCustomCars
Nov 22, 2010 08:24 PM
Lodi Dodi
Nov 12, 2010 06:26 PM
mcaanda
Dec 15, 2009 08:31 PM
jorge1
Oct 9, 2009 12:17 PM
Stopphn
Headers, Intake, & Exhaust
Jun 1, 2008 07:24 PM
