No Heat
Old Dec 14, 2006 | 04:11 PM
PELKEY1919's Avatar
PELKEY1919 is an unknown quantity at this point
Default No Heat
I have a 1999 2 door Blazer-I only get cold air at all times. Blower works fine. What would be the best way to troble shoot this?What do I check 1st and so on. Need help ASAP Thanks All
Old Dec 14, 2006 | 04:22 PM
Jigg's Avatar
Jigg is an unknown quantity at this point
Default RE: No Heat
Sounds like your heater core is plugged up. Take both radiator lines off of the firewall and put a garden hose on couplers coming out of the firewall. Alternate between the two until the water is flowing out of the open coupler freely and has no more sludge coming out. Run the truck for a little while, and add more antifreeze as necessary.
Enjoy your hot air.
Old Dec 14, 2006 | 05:34 PM
Default RE: No Heat
It is very possible that it is a plugged up core. But before pulling the hoses off and flushing it out, test the temperature on both of the hoses going into the firewall. If they are both hot, then most likely coolant is flowing through them fine. If one is noticably cooler than the other, chances are you have an obstruction.
Also, check the radiator level by removing the cap on the radiator. Do this with the engine cold so as not to scald yourself. Fill the radiator as necessary and bring it up to operating temperature. Fill the coolant tank to just above the HOT line and see how that works.
Old Dec 14, 2006 | 05:37 PM
Jigg's Avatar
Default RE: No Heat
ORIGINAL: swartlkk
Good call, I forgot that part :lol:
CSCustomCars
Nov 22, 2010 08:24 PM
Lodi Dodi
Nov 12, 2010 06:26 PM
mcaanda
Dec 15, 2009 08:31 PM
jorge1
Oct 9, 2009 12:17 PM
Stopphn
Headers, Intake, & Exhaust
Jun 1, 2008 07:24 PM
