No heat- searched
Old Nov 17, 2007 | 10:26 AM
WS6THNDR's Avatar
WS6THNDR is an unknown quantity at this point
Default No heat- searched
Hello. My 2000 4x4Jimmy has no heat. Fan blows good. I checked coolant level-ok. Both lines in and out of heater core are Ice cold?? Now what?
Thanks,
John
Old Nov 17, 2007 | 11:34 AM
hillbillyinOhio's Avatar
Default RE: No heat- searched
is the heater core clogged?? pull off the hoses and flush it out.
Old Nov 17, 2007 | 03:29 PM
Chevy Lover's Avatar
Have you done anything with the cooling system lately?
It sounds like the coolant is low because you should be getting heat to at least the inlet hose of the heater core.
Remove the heater hose from the heater core and see if there is any coolant in there.
It sounds like you have an air lock in the system.
Old Nov 20, 2007 | 07:02 AM
junkmonkey's Avatar
junkmonkey is an unknown quantity at this point
A simple check is to remove the thermostat. This will allow heated coolant to free flow through the engine and heater core. If after removing the thermostat, the lines to the heater core get hot (with engine temp up) then replace thermo with a new one. If one line into heater core gets hot, but the other is not, then the heater core is plugged. You can reverse flush the core with a garden hose and some misc fittings to make a hose rig to attach to the core, or you can disconnect the line back to the engine and reverse flush from there.
Some other things to check: does your coolant level drop occassionally? If so, check your oil. Is it chocolate milky? If so, you have a leaking intake manifold gasket which should be replaced immediately. With engine cold, is the coolant level low? If your IMG's are not leaking, park the vehicle with the front end raised (radiator at high point), start engine, slowly fill radiator with 50/50 coolant mix to drive out (burp) any air trapped in system. Good Luck.
Little Roober
Lifting Tech
Feb 13, 2012 10:02 PM
chiefbong360
Jan 4, 2010 10:27 AM
livlifes2short
Lifting Tech
Oct 12, 2009 01:26 PM
redpeppers
Apr 7, 2007 04:55 AM
j1cs
Jan 15, 2007 05:03 PM
