no power wont go over 1700 rpm HELP
Old Jun 14, 2010 | 02:50 PM
95ls2door's Avatar
95ls2door is on a distinguished road
is it bad to run no cat at all just put a cherry bomb in its place will that hurt anything i done it on 2 other trucks i had both jeeps
Old Jun 14, 2010 | 03:31 PM
rriddle3's Avatar
Since not replacing a catalytic converter would put you in violation of Federal law, we do not discuss that option on this forum.
Old Jun 14, 2010 | 05:12 PM
95ls2door's Avatar
ok didnt realize that sorry.
Old Jun 14, 2010 | 08:06 PM
Shalom's Avatar
Shalom is on a distinguished road
Had the exact same thing happen to me not too long ago. Replaced the cat, didn't help. Turns out this truck was a California spec model, unbeknownst to me (cuz I bought it in Jersey) and it had two cats... it was the one in the Y-pipe that was stuffed up. Replaced that as well and it started working fine.
(For a whole two weeks, then the manifold gasket blew out... that's another story...)
Old Jun 15, 2010 | 05:03 PM
95ls2door's Avatar
well i "modifed" my exuast and am about take it for the frist long ride wish me luck! i let u guys know
Old Jun 15, 2010 | 10:59 PM
95ls2door's Avatar
well its not fixed the cat was no the problem any other suggestions ????? i know i need a new 02 senor one of the wires is broke. that wouldnt cause me to have a studder and lose power after drivin for a bitt abouve 2500 would it.. i am a a loss idk what else to do. dont have the money to take it to the shop.
Old Jun 16, 2010 | 07:00 AM
Nvidia78's Avatar
Nvidia78 is on a distinguished road
maybe the cat was bad for so long that pieces went thru to the muffler and plugged it up, I have heard of that happening as well
Old Jun 16, 2010 | 09:36 AM
95ls2door's Avatar
both screens were still in the cat
Old Jun 16, 2010 | 11:38 AM
Audihoe's Avatar
Audihoe is on a distinguished road
Which O2 sensor is broke? If it's the air/fuel sensor then that could cause the truck to run rough. I'd replace the broken sensor first.
My subaru had a similar problem. It would try to stall and run horrible until i went over 3500 rpm. Found the air/fuel O2 was bad.
Old Jun 16, 2010 | 12:03 PM
rusty91's Avatar
rusty91 is an unknown quantity at this point
check the engine oil to see if you can smell gas on 95s you have the central injector which is known for its problems gas in the oil is a telltale sign also check fuel pressure
