No pressure in cooling system, normal engine temp
Old Apr 20, 2011 | 06:46 PM
Mark_D's Avatar
Mark_D is on a distinguished road
Default No pressure in cooling system, normal engine temp
Hello,
I hope somebody can point out a cause for these symptoms. I'm out of ideas, except maybe that are is air in the cooling system. Read on...
For some time (since even before changing the t-stat) my cooling system has seemed to keep the engine at the proper temperature and run properly except that the upper radiator hose would always be soft when running. Then I had the Dex-sludge problem and it started running w/ the temp gauge at 145. I flushed the system and put in a new t-stat. Everything was back to normal except I don't think there was pressure in the upper rad. hose.
Recently the water pump started leaking a lot. Just got it replaced and put a new radiator cap on. Again, seems to work fine but no pressure in the upper rad. hose. I have always had heat too.
Any ideas what could be causing this? I have driven 20 miles since the water pump and 8 since the radiator cap and the coolant was full then. Could there really still be air in there?
Thanks in advance peepz!
Old Apr 21, 2011 | 06:33 PM
Mark_D's Avatar
Update: It seems like a new radiator cap did fix it after all...seems to hold pressure today. I didn't drive too far on it though. I will update again after I get more miles with it...
zakm0n
Jan 9, 2011 07:31 PM
blazer073
Sep 9, 2010 10:58 AM
wglassbrook
Oct 14, 2009 04:18 PM
gsh4386
Mar 19, 2008 08:27 AM
