No primary voltage need schematics
Can anyone help me get the ignition chematics for a 4.3ltr 2000 blazer with EDI ignition?
I just changed the timing chain and gears on the truck, and may have wiring problems because I had to raise the engine to remove the pan. Any help will be welcomed, Thanks.
What parts of the ignition system do you require schematics for. My references have it split up by sensor, etc, not a whole system diagram...
Also, you could always consider a subscription to AllDataDIY.com.
Super! Gotta work today, but will hit the garage tonight to begin troubleshooting. Suspect the PCM is going, but had no codes to that direction. I figured with the amount of miles, it'd be a safe bet the timing needed a going through.
Man, that was a tough job!
Thanks Swarty!
Thanks Swarty!
2001Blue
Dec 31, 2010 12:16 PM
Schrade
Mar 16, 2010 02:42 PM
