No start and sudden dying
Old Apr 15, 2011 | 08:21 AM
kgkern01's Avatar
kgkern01 is an unknown quantity at this point
Default No start and sudden dying
So my truck all of a sudden now doesn't want to start. I've verified it's not a fuel problem with a fuel pressure gauge and also with starter fluid. It hasnt started in a week. Last night I did get it to start up, which it did seem to start like normal again, drove to the gas station? Filled up, started up again ok, then when getting on on-ramp the engine simply died, as if I had turned the key to off. What could cause such a strange problem.
Old Apr 15, 2011 | 09:02 AM
What are you driving?
Have you taken a look through the thread linked to below:
No-Start - Engine Cranks OK - Ignition System Diagnosis
Old Apr 15, 2011 | 10:26 AM
kgkern01's Avatar
2001 Blazer LT 4x4
Old Apr 19, 2011 | 08:33 AM
kgkern01's Avatar
So i removed the coil and coil wire, reattached them and now it runs and starts fine, is it possible the coil wire came loose causing it to just shut down? Also I've noticed noise coming from the distributor cap, which quited when I put my hand on it and lightly pushed on it. Could it also be a bad cap and rotor causing it?
Old Apr 19, 2011 | 12:22 PM
It is definitely possible that a loose coil wire is to blame here. I have seen plug wires work their way off of the cap terminals and even off spark plugs due to trapped air in the boot. This is especially true if you are using dielectric grease to seal up the boot. I have a few home-made tools (a piece of copper wire bent into a hook on the end) that I use when connecting wires that allow the air to escape when the boot is slid onto the terminal/plug.
trevorclark2
Jul 28, 2011 08:43 AM
ruralite85
Mar 31, 2011 08:17 PM
favilac
Sep 4, 2010 04:25 PM
Doc Z
Apr 12, 2010 10:08 PM
Big L
Mar 14, 2008 12:25 PM
