no throttle response
Old Jun 16, 2009 | 10:07 PM
groundhogman's Avatar
Banned
groundhogman is on a distinguished road
Question no throttle response
2000 blazer 4x4 2 door 4.3L, after my truck sit all day at work and i get ready to go home at start it up and put it in gear there is no throttle response, only very very slight. it doesnt matter if i put it in foward or reverse, but after a minute or two it warms up and goes away, please help, thanx!!!!
Old Jun 16, 2009 | 10:27 PM
Does it act the same when you get in it to drive it to work in the morning?
Old Jun 16, 2009 | 10:31 PM
Banned
actually no it doesnt that never even dawned on me!!!!!
Old Jun 16, 2009 | 10:37 PM
Typical 8-9 hours between when you get to work and when you leave?
What are the weather conditions? Rainy(humid) or dry? Hot or cold?
When was the last time you did a full tune up?
Old Jun 16, 2009 | 10:57 PM
Banned
full tune up plugs, wires, cap, rotor, oil, oil filter, air filter, clean MAF sensor with MAF sensor spray cleaner, as far as the weather goes it does not have any affect, here lately in virginia its been wet and rainy, hot and dry it still does this problem religiously
Old Jun 16, 2009 | 11:12 PM
With the engine running, check the fluid level and condition in the transmission.
Old Jun 16, 2009 | 11:28 PM
Banned
i checked all that and the fluid is new and smells and looks new it has 73,000 on it now and the transmission was serviced at 69,900, but the problem im having is the engine rpms are not moving at all with the pedal past half throttle, only until it seems to warm up after a minute or two then it seems fine, also my scanner is showing my TPS is 0% at idle and 100% at WOT
djback
Jan 22, 2012 09:35 AM
Chenzo
Engine & Internal
Mar 29, 2011 01:56 AM
ablazer00
Sep 4, 2010 01:43 AM
mackpipe
Sep 3, 2010 02:14 PM
Grinch 85K5
Nov 25, 2009 07:36 PM
