Non starting 1999 RHD 4.3
Old Jul 31, 2009 | 07:03 AM
BooTs's Avatar
BooTs is on a distinguished road
Post Non starting 1999 RHD 4.3
After running out of fuel and subsequently replacing the fuel pump (see other threads) the vehicle still will NOT start. I need to start from scratch to locate the problem.
The vehicle has not faultered in the 8 years (105,000 miles) I have had it, so I have no in depth experience of working on it, except for the usual maintenance.
I have am going to buy a suitable scanner to try an source the fault but any advice and tips would be appreciated from the forum. Also which workshop manual is the best - Haynes or Chilton?
Living in deepest Normandy means that there are no local workshops with suitable experience of Chevys.
Many thanks
Old Jul 31, 2009 | 11:44 PM
Have you tested the fuel pressure?
On the manual front, neither is acceptable in my opinion. See if you can find yourself a factory service manual on eBay. Here is one: 1999 CHEVROLET S10 TRUCK BLAZER SHOP SERVICE MANUAL
Old Aug 1, 2009 | 06:43 PM
bandidolenny's Avatar
Have you tried cycling the key on and off a few times to prime the fuel system?
Haynes and Chiltons manuals are both a joke and should only be used for the most basic of suggestions. As Kyle said... locate a factory service manual.
Old Aug 2, 2009 | 04:15 AM
BooTs's Avatar
Thanks for the suggestions. Doing a back to basics check on everthing just in case I missed something. Ordering the manuals this weekend.
Thanks again
Old Aug 6, 2009 | 05:28 AM
BooTs's Avatar
Awaiting delivery of manuals, thanks for pointing me in the right direction.
Have now rechecked fuel flow, have fuel pressure, also have spark at plugs. Still not firing even pouring fuel fown intake.
Have noted that engine fault light stays on. Will a scanner indicate what fault I have or what is the next stage.
Fed up banging my head against the wall - hence the request for, what might seem simple, help.
Cheers
Old Aug 6, 2009 | 07:54 AM
jleonards's Avatar
jleonards is on a distinguished road
Have you checked compression? I was recently working on another GM car and had spark, fuel...but the timing chain had broken....the valves were not closed so the car wouldn't start....just a thought
Old Nov 8, 2009 | 06:05 AM
BooTs's Avatar
Finally after having to leave the vehicle for a month now have the Blazer back on the road. Replaced the fuel pump and even though it appeared that the ignition was OK replaced the distributer cap and rotor. Engine running very sweetly
Just proves that going back to basics works.
Thanks to all for help & suggestions.
Dobe Rottie Gang
Jun 11, 2015 04:25 AM
shaner63
Jun 24, 2011 11:03 AM
BooTs
Mar 29, 2011 09:07 AM
kiwiblazer
Apr 12, 2008 05:44 PM
kiwiblazer
Apr 12, 2008 02:11 AM
