Not good..head gasket or intake ...pls help
Old Nov 7, 2007 | 11:27 AM
rriddle3's Avatar
Default RE: Not good..head gasket or intake ...pls help
This just does not sound like a crankshaft issue to me. I'm thinking that it may be a fuel supply issue since it doesn't seem to have enough oomph to run, but will try to crank. Have you tested the fuel pressure? What about fuel filter replacement?
Old Nov 7, 2007 | 01:46 PM
nitrous2126's Avatar
nitrous2126 is an unknown quantity at this point
ok heres the update...bad battery to start..only 6 months old...new one put in and alt. is fine tested...starts and runs fine but sounds like something is rattling around inside either the exhaust or maybe oil pan??? i dont know exactly where... when i start it though it make a big bang/rattle when it first starts but once its started it seems perfect... could there be something floating around in the oil and cause that loud noise when i start it? maybe warped crank??? but if that was the case you would not think it would run so well after start...
Old Nov 7, 2007 | 01:59 PM
maybe broken starter tooth???? whatta ya think ...maybe thats causing the gringing sound when starting?
limited edition 1
Jan 27, 2023 11:07 AM
Melrock83
Jul 3, 2012 06:51 AM
mylittletonkatruck
Mar 7, 2012 02:04 PM
J.R. Clay
Mar 17, 2011 08:22 PM
01gmcjimmy
17
Jan 4, 2008 10:17 PM
