Not Starting 95 4.3
Old Jul 2, 2008 | 07:30 PM
bob51's Avatar
bob51 is an unknown quantity at this point
Default Not Starting 95 4.3
I have a 95 Blazer with 4.3 with the CMFI injection. It will not start. It has good ignition. If I spray starting fluid in the intake plenum it will start and seems to run good while it is started. It had been giving an EGR code so I have replaced the EGR valve it seems to be unrelated. The fuel pump is running and delivering fuel. Although the pressure is at 40 psi, the book calls for 58 to 64 psi. I would assume this is the problem except when it is started it runs and accelerates fine. Where is the pressure regulator on this thing and is it replaced separately from the pump?
Thank you for any ideas.
Old Jul 2, 2008 | 08:24 PM
rriddle3's Avatar
Default RE: Not Starting 95 4.3
[sm=welcomesign.gif]to the Forum, Bob. We have plenty of threads here about the exact problem you describe. Have you used the 'search' function or read through any of the postings? Give it a shot, and if you are still stumped, post back up and we'll see what we can do.
stschuyler25
Nov 21, 2010 09:34 AM
cgrett
Nov 15, 2010 09:08 PM
Sprocket
Mar 20, 2008 09:39 PM
fzr confused
Mar 28, 2006 12:31 AM
Im_Bryan
Mar 29, 2005 01:20 PM
