o2 sensor
Old Mar 27, 2009 | 07:58 AM
19jimmy99's Avatar
19jimmy99 is on a distinguished road
Default o2 sensor
is there away to tell what o2 sensor need to be changed without takeing them out all i no is the garage told me i need a new o2 sensor never told me which one
Old Mar 27, 2009 | 09:05 AM
The code will tell you which one.
Judging from your screenname, I assume you have a 99 Jimmy. If that is the case, you will have two upstream sensors (the ones closest to the engine) and one downstream sensor (after the cat). B1S1 is the driver side upstream sensor. B2S1 is the passenger side upstream sensor. And your down stream sensor could be called B1S2 or B1S3 depending on the software revision.
joey
Aug 27, 2012 06:33 PM
GM hater
Jan 9, 2010 02:32 PM
theeviltwinn
Oct 23, 2009 06:37 AM
daniel010
Feb 2, 2009 06:50 AM
Spartan66
Jul 11, 2008 02:34 PM
