O2 sensors are a pain in the neck!
Old May 5, 2013 | 10:56 AM
Helter80's Avatar
Helter80 is an unknown quantity at this point
Default O2 sensors are a pain in the neck!
I must say, trying to get any room to remove the original O2 sensors out of these trucks is a royal pain in the neck! Mine on the passenger's side of the engine is the one that I have to remove and theres no room to get in there. I have an O2 sensor socket, but the pipe is so close to the transmission pan. Does anyone know any "trick" for this? I've tried searching the forum, but found nothing but threads with other questions about the O2 sensors. Thanks!
BTW, its a 2004 4WD 2 door, if that helps.
Old May 5, 2013 | 12:52 PM
Try putting a universal on the socket, and an extension off of the universal, to a 1/2" drive ratchet. Gotta think outside the box Run the universal and extension forward, next to the sensor. Probably help to heat the sensor first too.
Old May 5, 2013 | 12:55 PM
4X4GS10B's Avatar
4X4GS10B is on a distinguished road
I've used a line wrench it got it out...
Old May 5, 2013 | 12:56 PM
Yup, there ya go, thinking outside the box got it! Good idea!
Old May 5, 2013 | 01:19 PM
Twip's Avatar
you should be able to use a 7/8 (i think thats the size) wrench to get it out.
Old May 5, 2013 | 02:29 PM
1sttimejimmyowner's Avatar
1sttimejimmyowner is on a distinguished road
Angry
Mine are welded in so I cant get them out unless I use ayctiline torch to remove them.
von scott
Tires and Wheels
Jun 2, 2010 08:47 PM
raiders09
Jan 31, 2010 12:43 AM
BlackBlaze
May 6, 2007 11:33 AM
kornphlake
Dec 18, 2006 02:18 AM
wvpurplejimmygirl
Dec 13, 2005 05:32 PM
