Obd question with GM tech 1
Old Aug 9, 2013 | 11:51 PM
bizzs's Avatar
bizzs is on a distinguished road
Thanks for the info Ranjam.. Those adapters you have are exactly what I have. According to the bosch website, the P/N 02001575 crosses over to my P/N 3000053 adapter. This should work and I cannot understand what the deal is with this tech 1. My Snap-on solus will read the dtc, but it will not do the functions like the tech 1. The tech 1 works perfect in my son's, 95 skylark, minus the adapters that are required for the blazer. I don't know what is wrong, but if you come with an idea, let me know. My pcm is mounted on the coolant bottle.
Thanks again,
bizzs
Old Aug 10, 2013 | 10:44 AM
Ramjam2112's Avatar
Ramjam2112 is on a distinguished road
Default Bad conection?
Thanks again,
bizzs
Flipping through my factory service manual;
Check your 8th digit VIN or check your RPO codes and look for either a L34 or LB4. it is most likely a "Z" or LB4 indicating a VCM controlled system which is the big black box mounted above the coolant bottle. If that is the case, you will need an additional item called a Vehicle Interface Module.
Wish I could help you find one as they are getting increasingly rare.
Send me a PM
Old Aug 10, 2013 | 02:34 PM
Ramjam2112's Avatar
Default I found you the adapters you need
Thanks again,
bizzs
I found you that Vehicle interface module you need.
Send me a PM for the info.
rowe
22
Dec 10, 2018 10:45 AM
racsan
Oct 23, 2011 08:58 PM
GuardianDragon
Sep 6, 2011 12:36 PM
DemoCar82
Nov 14, 2010 09:05 AM
blazermark
May 18, 2006 08:01 PM
