OBDII ECM vs ABS
Old Jan 11, 2011 | 03:45 PM
billbobagns's Avatar
billbobagns is on a distinguished road
Default OBDII ECM vs ABS
Is it true that data about my 1999 GM ABS is on GM-UART and that is on pins 6-14?
Is it true that my China OBDii Bluetooth adapter can't support GM UART, but some expensive one can?
Old Jan 11, 2011 | 07:25 PM
The serial bus pin in the DLC is #2. The UART pin is #9.
Old Jan 12, 2011 | 01:35 PM
Slow down a little Swartlkk;
1) all data available from the OBD port is "Serial Data"
2) Pin 2 is the J1850 (Bus+) pin and pin 10 is the J1850 (Bus-) pin
3) Pins 1-3-8-9-11-12-13 are listed in the standard as "Manufactures Discretion" Are you saying the GM UART serial data is on two of these? Do you have more information on which pins those are and which protocols they use?
Old Jan 12, 2011 | 05:02 PM
Slow down... What seems to be your difficulty?
Pins 1, 3, 6-8, 10-12, and 14-15 are not used on the GM DLC found in the 98-02 S-series SUVs according to my references. Pin 2 is stated as the 'Serial Data Signal - Class 2 - 10400 Baud - Diagnostic to ALDL'. Pins 4 & 5 are both grounds. Pin 9 is stated as the 'Serial Data Signal - UART - 8192 Baud - Primary'. Pin 13 is the diagnostic signal wire for the NP1 transfer case (if equiped) and pin 16 is +12V fused battery power.
Old Jan 12, 2011 | 05:15 PM
Thanks for clarification.
Old Jan 12, 2011 | 05:28 PM
Do you know what is on Pin 13? Is it serial data from the Transfer Case Computer? Does ScanXL or Enginuity make use of this line?
Old Jan 12, 2011 | 05:39 PM
UberFail's Avatar
UberFail is on a distinguished road
think u missed him saying what 13 was
Old Jan 12, 2011 | 06:06 PM
Pin 13 is the link to the diagnostic port on the TCCM. On NP1 equiped vehicles, the codes can be read by watching the 4wd switch lights after grounding pin 13 as described in the OBD2 NV233 Diagnostics thread. That thread also has the DLC pinout which is linked to from my photobucket account. I couldn't find it earlier or else I would have attached it.
roddy
Jun 28, 2012 04:52 PM
raptorman
Nov 24, 2010 10:50 PM
classic_cruiser
Jul 29, 2007 05:09 AM
disturbedgame
May 8, 2007 10:32 AM
johnny_5
Engine & Internal
Mar 31, 2007 02:58 PM
