Oil
Old Jan 22, 2009 | 11:49 PM
cr8390's Avatar
cr8390 is an unknown quantity at this point
Default Oil
Ok guys i know there are a lot of threads about the synthetic oils and what not, if looked at alot of them. My questions are simple right now im using the castrol gtx high mileage, ive been using it for about 4-5 oil changes and havent had a problem. I just want to switch to synthetic oil. I've been googling alot and ive been on bobistheoilguy.com but i heard rumors that mobil 1 switched there formula or something so now its not a true synthetic or some crap like that. So which is better mobil 1 or Pennzoil full sythetics? Also right now im using a K&N oil filter because it's got the nut on the top make it easier to take it off in my garage, if i switch to synthetic can i still use a K&N filter or should i switch to lets say a mobil 1 filter or something?
Thanks
Old Jan 23, 2009 | 06:26 AM
96mgc's Avatar
96mgc is an unknown quantity at this point
Default RE: Oil
I would never use any kind of Pennzoil (SLUDGE MAKER)
Personally if I would go synthethic, I would go Amsoil all the way. Got several motors, transmissions, and a few othertoyswith it already. Always starts even on coldest days. Less repairs needed over long time use, cleaner engine (see that when you change Plugs, oil filters and oil), Gaskets dont go to crap as fast, and a pick of 7500 or 25,000 change options. But that is just my 2 cents on the subject.
Old Jan 23, 2009 | 07:12 AM
Default RE: Oil
I wonder how old that opinion of Pennzoil is... The new Pennzoil Platinum full synthetic oil is a very good oil.
Old Jan 23, 2009 | 08:07 PM
cr8390's Avatar
Default RE: Oil
so kyle would you recommend it over the mobil 1?
Old Jan 23, 2009 | 08:32 PM
Default RE: Oil
Mobil 1 EP and Pennzoil Platinum are both good oils. I am going to be trying PP at my next change in the Rainier. I have been using M1 for awhile now though.
Old Jan 23, 2009 | 08:50 PM
cr8390's Avatar
Default RE: Oil
alright thanks i might try the PP
Old Jan 23, 2009 | 09:05 PM
c0a8l0v6i8n9's Avatar
c0a8l0v6i8n9 is an unknown quantity at this point
Default RE: Oil
I use PP and have no problems at all with it. I usually pair it up with a fram filter. I would suggest it
Old Jan 23, 2009 | 09:34 PM
cr8390's Avatar
Default RE: Oil
eh i dont really like fram they brake really easily and i just think there cheaply made, im using a k&n now which i love and i've used puralotr in the past. But when i change my oil to PP ill either use a k&n or maybe a mobil 1 idk yet
Old Jan 24, 2009 | 08:06 AM
bodean's Avatar
bodean is an unknown quantity at this point
Default RE: Oil
i have noticed that in any vehicle that we put synthetic in it seems to have lower oil pressure. only a couple pounds lower but it does drop ??
Old Jan 24, 2009 | 08:22 AM
rriddle3's Avatar
Default RE: Oil
I don't believe that it is necessarily because the oil is synthetic. Each oil grade has a viscosity range that is permitted for that weight. The brand(s) of synthetics you have used probably are falling inthe lower end of the permitted range for the weight. Lower viscosity will equal lower pressure. Nothing to worry about.
Ak95Blazer
Jan 7, 2009 06:56 AM
todaresqSL2
Nov 10, 2008 01:47 PM
FoxTrota
Aug 13, 2008 07:24 AM
shooter2499
Feb 4, 2008 09:23 PM
KA3AX
Jan 15, 2007 01:33 AM
