Oil chage filter question
Old 11-23-2015, 11:46 AM
Kuntryboy816's Avatar
Kuntryboy816 is on a distinguished road
Default Oil chage filter question
It's time to change the oil on the wife's Blazer (2000/4.3) and I have just a quick question. The PO told me to make sure I use a GM specific filter b/c it has some sort of anti-flowback valve to keep the oil from draining back into the pan? ....supposedly keeps the engine lubricated during startups? I couldn't find any relevant facts using the search feature here.
Any help/direction is much appreciated.
Old 11-23-2015, 12:50 PM
Toocute350's Avatar
Toocute350 is on a distinguished road
If you don`t have a P.O. box look up summit racing.com The reason why because they don`t deliver to po boxes.But if you want a real oil filter..Look up K&N filters.Not sure if you have the deep pan 2 7/8 or the regular pan 2 1/4.Look at the pan is it flat or does it drop down to a deeper section.If it drops down to a deeper section..It`s a deep pan.I`ve always used k&N air filters and oil filters going on about 15 yrs. now.Or you can look up K&N.com themselves to get the part#.I have a 2wd blazer I use the bigger 4x4 filter.It`s only about an inch taller in size.I changed out my fuel filter about 4 months ago with the K&N brand filter.It `s up to you.But they do have co`s out there that make a much better product compared to G.M.
Old 11-23-2015, 01:07 PM
Thanks for the quick response and the info. I'll have to get her up in the air and check the oilpan to determine which pan it is.
Old 11-23-2015, 01:19 PM
Toocute350's Avatar
Not a problem
Not a problem!
Old 11-23-2015, 02:18 PM
CWBDDSPC's Avatar
CWBDDSPC is on a distinguished road
I am not familiar with differing depths of the oil pan. I do know there is a standard and deep pan when it comes to the transmission, but this will have no impact on the oil filter.
As far as a check valve being in the oil filter, yes, I do believe there are models that have them. It is fine to use whatever #AC Delco filter GM recommends for the vehicle. I do not know the # off the top of my head. Any equivalent oil filter you like is also fine. I personally think K&N products are over-rated, but to each their own. I run WIX oil filters myself.
Hope this helps!
Old 11-23-2015, 04:15 PM
I definitely think K&N oil filters are over rated! I like their air filters so long as they are not over oiled on a MAF equipped vehicle, but that's the only thing from them.
Add another vote for WIX filters as well. NAPA brand filters are made by WIX.
Old 11-23-2015, 04:19 PM
richphotos's Avatar
richphotos has a spectacular aura aboutrichphotos has a spectacular aura aboutrichphotos has a spectacular aura about
WIX filters all the way.
I think k&n oil filters are garbage, if I wanted to pay for full cardboard internals I would try to make my own filter out of a soup can, an old box and some shop towels.
Old 11-23-2015, 04:25 PM
CWBDDSPC's Avatar
I would like to see that actually
Old 11-23-2015, 04:37 PM
But they put the nut on the bottom of the filter that makes it SOOOO easy to remove it!
Old 11-23-2015, 06:21 PM
blazer47's Avatar
blazer47 is on a distinguished road
we own 3 blazers. one has over 250M miles on it. from the get go I have used mobil one synthetic in all of them. along with a mobil one filter.
I've never heard of the anti flowback thing.
I've used fram filters until a few years ago when I heard they started making them cheaper.
Quick Reply: Oil chage filter question
