You should be fine; just make sure you repair any pinhole leaks. The system is always pressurized, so a leak makes the pump overwork to maintain the correct pressure. That's what I assumed killed my pump prematurely. Looking at the lines for any moisture or signs of fuel or a leakdown test can help determine a leak in the system. I do the test twice a year as a precaution. And as far as the cooler lines, I would not shy away from ACDelco brands as a second choice.
Is there anything I should watch out for or ask the dealer to do with regards to the oil coolant line job? For instance, are there any gaskets/O-rings/etc I should make sure they change as well? Anything I should do when inspecting their completed work? Thanks!
Not really; they should know what to do. When I bought mine, they did come with new O-rings and gaskets. That's a given. Why would you risk using the old ones? I would just keep and eye for any oil leaks after install and oil level for first few weeks. I did have them do a oil change using my own purchased quarts of Mobil 1 HM with a ACdelco filter and new felpro gasket for oil plug. Nothing your mechanic can't handle.
I would have them also replace the gasket and o-ring between the oil-line to engine block adapter and the block.
Can you please illustrate what you mean? Do you mean the fist-sized chunk of metal that the oil filter screws into? And then do you mean the gasket between the fist-sized thing that the oil filter screws into and the engine?
Look at this picture (not the actual part only as example) do you see the O-ring seals? Those should come with your new lines. Does not have anything to do with the oil filter, but the lines do connect to the oil filter adapter (fist-sizsed thing), So to clarify, your lines should include O-ring gaskets that go between the oil filter adapter and the line itself.
The Engine Oil Cooler Lines assembly part 15194577 is 10, 11, 12, 15 in the below diagram on a 2004 Chevy Blazer RWD 4 Door LS trim. Are you saying to replace anything else?
My oil lines are fixed!! The part from the Chevy dealer came in a plastic bag with a general motors sticker having a hologram on it. There was no paper tag as in the photo above, but they assured me it was a legit part. The origin was Canadian with "imported" parts it said. My vehicle now stinks less and I think I can tell that it runs better. More specifically I think my lungs no longer burn when I drive the car. I kept my old oil lines and I am thinking of trying to make them into racing-grade lines.
If you know how to do a NASA-grade fitting of the hard lines to an AN connector I would be very interested. If this involves cutting, I also would want to know how to make the line clean enough for use with the engine oil, that's a little scary over 100k+ miles of intended usage, I would hate for microscopic debris to break off and harm the engine. There would also be the question of a seal which can last for that long or longer,... and I am vague whether there are o-rings/gaskets in need of replacement on the radiator or oil filter sides.
