Oil Cooler / Filter Lines
Old Oct 21, 2013 | 06:34 PM
cferry7's Avatar
cferry7 is on a distinguished road
Default Oil Cooler / Filter Lines
1995 GMC Jimmy SLT 4WD
I can't locate in 2 manuals this torque spec.
Bolt Torque spec for the Bolts which attach the Oil Lines to Oil Filter Adapter and under Engine Oil Feed ?
Web page link ?
Even if it's for a similar vehicle would be sufficient for now.
Appreciate any help.
Old Oct 21, 2013 | 09:05 PM
cleburne red's Avatar
I seem to remember reading on here when I did mine that it was pretty light. 25 ft-lbs? I've read that if they are over torqued, it will cause the gaskets to fail, and you'll be right back where you started with oil leaks!
Old Oct 21, 2013 | 11:00 PM
chris015's Avatar
not sure. done many of em. just turn till its good hand tight. then another 3/4 turn. done. dont wanna squeeze em too tight or they will leak.
Old Oct 22, 2013 | 12:07 AM
Toby Hanson's Avatar
Toby Hanson will become famous soon enough
I just replaced mine in the spring. The torque spec is 26 ft-lbs. I seem to recall that you don't want to overtighten them for some reason, possibly because the metal is soft and the fittings could distort.
fslobodecki@yahoo.com
Apr 15, 2011 03:29 PM
subarugt06
Mar 6, 2011 11:21 AM
nineteensixtycaddy
Mar 28, 2010 02:29 PM
fondo
Nov 10, 2008 04:50 PM
Jetfixer
Jul 11, 2006 05:02 AM
