Oil gauge readings.
Old Jul 14, 2015 | 02:40 PM
Bolbol's Avatar
Bolbol is on a distinguished road
Default Oil gauge readings.
I've recently noticed that the oil gauge of my car changes from low to high at random times.
When im driving and my foot is on the gas its mostly reading at 55(just a bit below the dash line that is between the 40 and 80)
The rest of the time it goes down to 25 mostly when its idling or driving slow in traffic.
I have heard that the sensor can be bad but people in those cases have readings which are way off like above 80. I am wondering if the actual oil pump is bad would I get a check engine light or any sort of noticeable symptom? I wanna know if there is a way to find out if its the sensor or the pump without changing anything because if its the sensor id like to let it be for now.
Thanks
Old Jul 14, 2015 | 03:10 PM
Most auto parts stores rent/loan/sell oil pressure guages. It requires removing the oil pressure sending unit from the engine and installing the guage in its place. Oil pressure should be tested with the engine at normal operating temperature both at idle, and at approximately 2000 rpm. At idle it should be at least 10psi, and approximately 60psi at 2000 rpm. If the pressure rises much above 80psi, there is a risk of the oil filter blowing apart, which will cause all oil to exit the engine very rapidly, causing serious damage to the engine.
Old Jul 15, 2015 | 07:11 AM
LesMyer's Avatar
Sounds perfectly normal to me.
Old Jul 15, 2015 | 09:27 AM
LannyL81's Avatar
Good luck getting the oil pressure sensor/sender out....very tight quarters at the base of the distributor. Would likely need to remove the distributor to get to it.
Old Jul 15, 2015 | 09:37 AM
Tajohns34's Avatar
Those oil pressure numbers sound pretty good to me.
Old Jul 15, 2015 | 10:23 AM
1sttimejimmyowner's Avatar
1sttimejimmyowner is on a distinguished road
Question Oil pressure guage not reading
Without starting a new thread since my question is similar before I removed my engine and trans my oil guage worked since I reinstalled both after being rebuilt it no longer works,what would cause this?
Old Jul 16, 2015 | 12:38 AM
akaSPITTYBAYS's Avatar
akaSPITTYBAYS is on a distinguished road
Crappy gage wire reconnect?
Old Jul 16, 2015 | 10:04 AM
That maybe the case or may not have been wired at all.What color are the wires that hook up and where are they at?Also can I remove the sending unit and add a after market guage?
Old Jul 16, 2015 | 05:16 PM
Bolbol's Avatar
The readings are fine but when i put it in reverse it jumps all over the place..along with the rpm dropping below 500 but doesnt stall
88Vic
Nov 2, 2010 09:53 AM
haze
Jul 27, 2009 11:00 PM
Bad Ramer Jamer
Sep 16, 2008 10:32 AM
Thor_449
Apr 6, 2008 02:35 PM
NCStone
Jul 15, 2006 02:52 AM
