Oil Leak
Old Nov 20, 2010 | 08:21 PM
Inspector126's Avatar
Inspector126 is on a distinguished road
Default Oil Leak
I have a 2002 S-10 Blazer. I noticed some oil on the floor. It appears to be coming from the front of the oil pan, above somewhere. There is no oil around any bolts holding the pan. Is it something as simple as replacing the gasket. Or is there something that runs into the front of the pan somewhere that will be nothing but grief. If so what kind of cost am I looking at? Thanks in advance.
Old Nov 20, 2010 | 09:59 PM
Possibly the lower intake manifold gasket is leaking behind the AC compressor and running down. Need to get a light and a small mirror on a stick and check it out.
Old Nov 21, 2010 | 07:21 AM
LannyL81's Avatar
Are you sure all the oil pan bolts are tight? This year is known to have a problem with the front two pan bolts not staying tight and falling out.
Old Nov 21, 2010 | 01:08 PM
1998MSO's Avatar
1998MSO is on a distinguished road
Another common source of leaks are the remote oil filter and cooler lines, take a look there.
ComputerNerdBD
Mar 20, 2013 12:33 AM
Kaser1026
Dec 30, 2012 05:58 PM
Bluebeastblazer57
Aug 11, 2012 11:05 PM
BubbaBrooks
May 18, 2011 08:38 PM
TAZ454
Jan 28, 2008 10:11 AM
