oil leak and emmissions
Old Feb 1, 2007 | 06:57 AM
sir otto's Avatar
sir otto is an unknown quantity at this point
Default oil leak and emmissions
Hello. I am new here so take it easy on me. I have a 96 s10 lt blazer 4x4. I have a oil leak that looks like it coming from the front of the engine. I have new oil lines so I can rule that out. It the front main seal on the crank shaft prone. I also have a emmissions problem. The trouble code says I have complete emmissions failure. I have 2 new O2 sensors, PCV valve and a new gas cap. Is the EGR valve bad or shouldI go get a vacume leak check done. If anybody knows how to drain and fill the transfer case let me know.
Old Feb 1, 2007 | 10:58 AM
Default RE: oil leak and emmissions
Oil leak could be valve cover, front main seal, oil pan gasket, etc. Really have to get things cleaned up and really have a look at where its comin' from.
On the code, what is the exact code?
ComputerNerdBD
Mar 20, 2013 12:33 AM
Kaser1026
Dec 30, 2012 05:58 PM
Bluebeastblazer57
Aug 11, 2012 11:05 PM
BubbaBrooks
May 18, 2011 08:38 PM
TAZ454
Jan 28, 2008 10:11 AM
