Oil pressure gauge 2000 Blazer..
Old Nov 7, 2008 | 02:49 PM
karl1979's Avatar
karl1979 is an unknown quantity at this point
Default Oil pressure gauge 2000 Blazer..
I'm not much of a mechanic, so can someone please give me a little overview of the purpose of my oil pressure gauge, and what the proper reading should be?
Thanks...
Old Nov 7, 2008 | 09:19 PM
rriddle3's Avatar
Default RE: Oil pressure gauge 2000 Blazer..
The purpose of an oil pressure gauge is to show the pressure the engine oil is operating under inside the oil passages of the engine. It is to be considered an averaged reading since it is actually the pressure at the sending unitat that moment. The old 'rule of thumb' is a minimum of 10 pounds per square inch (psi) for each 1,000 rpm's of the engine. Chevy considers 8 psi to be the minimum psi allowed at idle. In practice, most of our engines will have ~20psi minumum at idle, ~40psi cruising, and 60-70psi under acceleration. This varies from engine to engine as mine has ~40psi at idle and ~60psi at cruising speed. Bear in mind that factory gauges are not the most accurate in the world. A mechanical guage hooked to the sending unit is more accurate.
Old Nov 8, 2008 | 12:52 PM
^^Exactly^^
er0ck273
Sep 1, 2013 11:45 AM
RR3S10Blazer
Sep 28, 2011 12:06 PM
strong blazer
Feb 7, 2008 10:12 AM
Aaron_02
May 9, 2007 04:30 PM
guywm25
Nov 1, 2006 01:34 AM
