Oil pressure gauge goes from normal to zero periodically.
Hey everyone, on my 2001 chevy blazer v6 the oil gauge periodically drops to zero then will go back to normal. It will do this several times while im driving and it will sometimes stay all the way at zero for a long time before it comes back. Besides a faulty oil pump what else could cause this to happen? Could it be a cracked gasket? Or any other ideas would be great thanks.
Hook a mechanical pressure gauge to the connector at the oil pressure sending unit (top rear of the engine near the distributor) and verify the pressure readings. If the mechanical gauge shows normal, then the problem is with the sending unit.
Mine does the opposite, when fully warmed up and driving it goes from like 45 psi and pegs all the way up and goes back to where it should be, I am not to worried about it since its either a loose connection in the cluster or the oil pressure sensor acting up
Over fill on the oil can make the gage drop to 0, the crank whips the oil and the pump sucks up the bubbles. I know of this happening to some one b/c he got tired of having to add oil to his oil burner all the time.
the86ali
05-22-2015 01:39 PM
the86ali
TrailBlazer GMT360/GMT370 (2002-2009) Tech
04-19-2015 10:54 AM
castnhope
03-05-2012 05:10 PM
boscoedoodle
11-24-2009 10:56 PM
