oil pressure gauge reading at bottom
Old Nov 22, 2009 | 04:07 PM
rhaig's Avatar
rhaig is on a distinguished road
Default oil pressure gauge reading at bottom
Yesterday with the help of some friends, we replaced the intake manifold gasket. We forgot to plug in the lead from the oil pressure gauge so the gauge was slack (to the high side). So without removing the distributor, I felt around (blindly) and plugged the lead back in. Now the gauge reads fully to the other side. The pump is running, the oil is warming up as the engine idles, it's not making any odd noises. I'm not worried that oil isn't circulating. However that gauge mis-reading makes the check engine and check gauges lights come on.
I'm thinking I'll need to pull the distributor again and make sure I have everything seated right with the lead and plug. Does that sound about right? Suggestions or tips? This part I'll be doing myself, and I'm a bit shy of working on engines, with my experienced friends yesterday it was ok. But by myself I thought I'd ask here first.
thanks
Old Nov 22, 2009 | 06:15 PM
Just make sure that you mark the rotor tip location both when it is fully installed as well as when the distributor disengages from the cam drive gear.
Old Nov 22, 2009 | 07:28 PM
rhaig's Avatar
yesterday we only marked the installed position, and just had to try a few times to get it back in right. Marking the disengagement point is something I hadn't considered.
Thanks
TheNasty0ne
Dec 7, 2010 03:23 PM
83GMC-JIMMY
Oct 6, 2010 09:06 AM
88s10Blazer
Jan 27, 2010 04:44 PM
sleonh
Sep 22, 2009 07:15 PM
ant2297
Sep 28, 2008 07:40 PM
