Oil Pressure Help
![Question](https://blazerforum.com/forum/images/icons/icon5.gif)
Howdy,
Normally the oil pressure in my 2001 Blazer 4.3 4x4 idles at around 55-60. Today I was towing my trailer roughly 60 miles, and after dropping it back off, my oil pressure is now idling just under 40. The oil level hasn't changed, and nothing is leaking or making any new noises.
Is this normal?
PS: This is the trailer. I know it's a bit big to be towing, but it handled just fine.
Is this normal?
![](https://blazerforum.com/forum/attachments/2nd-generation-s-series-1995-2005-tech-41/26201-oil-pressure-help-0yv97yfl.jpg?dateline=1443036881)
![](https://blazerforum.com/forum/attachments/2nd-generation-s-series-1995-2005-tech-41/26202-oil-pressure-help-4pwsiacl.jpg?dateline=1443036881)
Looks like mine is 5psi higher than yours across the board. Probably just a difference in calibration of oil pressure sending unit, but mine also could be a little tighter clearances because it is new - haven't put my mechanical test gauge on it as my oil pressure is no longer a concern.
To the OP - 40psi at idle when hot is definitely not likely to be happening when using the correct 5W30 oil and a normal (non hi-volume) oil pump. Possibly a gauge problem. Put a mechanical test gauge on it.
LWegner
05-08-2011 08:25 AM
Spectreblazer
03-15-2010 11:16 PM
davidsv8mustang
02-18-2010 02:29 PM
Ak95Blazer
01-07-2009 06:56 AM
