Oil pressure pegged
Old 07-01-2020, 08:44 AM
Originally Posted by Randy Josphe Wells
​​​​​question about moveing the distributor I'm assuming you would undo the sparkplug an coil wires to get better access to removing the distributor. Once I do that an once I get a oil pressure gauge I undo the oil sending unit hook that up then I would have to put the wires back on the distributor to start the engine an then check the oil pressure?
Just undo the wires on the driver's side, then pull the cap off and flop it over to the side. Mark the position of the rotor on the distributor body with a Sharpie. Undo the clamp and lift the distributor straight up. The rotor will rotate a bit when you pull it up. Mark the "new" rotor position on the distributor body, too. When you want to reinstall the ditributor, line the rotor up with the second mark and drop it in. It should rotate as it goes in until it lines up with the first mark. As long as you don't turn the engine while it's out, that's all you have to do. No need to set the engine at TDC or anything like that. It makes it a pretty simple job.
Old 07-01-2020, 09:41 PM
dviles's Avatar
dviles is on a distinguished road
Although I've removed the distributor both times I've changed my sensor, I don't think you need to.
A 3/8 ratchet with the deep socket that fit the sender is the best setup. I tried a number of extensions and universals, and they really don't help. You're just all the way down and back behind the engine.
Good luck.
dviles
BeaterJimmy
07-18-2020 04:19 PM
memelove
08-30-2018 08:44 PM
cbenslay
01-16-2016 12:46 PM
garrett97
12-08-2010 01:47 PM
ivannj
02-13-2006 02:58 PM
Quick Reply: Oil pressure pegged
