Oil tube removal on 96' model
Old May 30, 2016 | 08:31 PM
Graveyard's Avatar
Graveyard is on a distinguished road
Default Oil tube removal on 96' model
Hello,
Before I broke something I thought I'd ask the correct procedure for removing the oil fill tube on the passenger valve cover. Also, I have my lower intake manifold off, what is the black cylindrical unit next to the thermostat?
I'd like to remove it so I can put the intake in a parts cleaner.
Thanks
Old May 30, 2016 | 09:36 PM
Oil fill tube unscrews about one half turn counter clockwise.
Directly forward of the thermostat is the EGR valve.
When installing the lower intake, make sure you follow the tightening sequence and torque specs. If it is not done correctly, it can do permanent damage to the engine:
Attached Thumbnails Oil tube removal on 96' model-intakemanifold001-copy.jpg
Old May 31, 2016 | 05:05 AM
Graveyard's Avatar
Thanks Capt. Hook
Old May 31, 2016 | 04:32 PM
Racer_X's Avatar
Racer_X is on a distinguished road
One thing to note here. If someone has had yours off to replace the O-ring, or for any reason, it's the exact same joint that is used for the oil fill cap. You can take the tube out and put the cap directly in the hole if you want.
However, there's an additional hole in the base of the tube, and a locking tab in any new ("virgin") valve cover. To get it out the first time, you have to turn it hard enough to break the locking tab. Use a strap wrench or some channel lock pliers at the base and turn counter clockwise. You'll hear a big snap sound as the tab breaks, and it will come right off after that. The broken tab isn't an issue. It's designed that way.
Old Jun 2, 2016 | 07:53 AM
Graveyard's Avatar
Oh. Alrighty then
I'm glad ya said that because I tried twisting it off and it still didn't want to come out.
I'm just going to remove the cover first and have a look from the underneath side as well.
Thanks
shopcarpro
Sep 6, 2012 12:01 PM
RIFLEMAN 308
Feb 13, 2012 07:39 AM
Numbchux
Mar 20, 2011 01:23 AM
Trip..
May 18, 2010 06:31 PM
KA3AX
17
Nov 20, 2007 06:00 PM
