Old Betsy is still bogging out! Please help!
Old Aug 19, 2012 | 11:07 AM
OldBetsy's Avatar
OldBetsy is on a distinguished road
Exclamation Old Betsy is still bogging out! Please help!
I replaced my ignition coil, fuel pump, fuel filter, spark plugs, wires, cap, and rotor and I'm still bogging out from extended stops. If I put the car in neutral at red lights and back in drive when I'm ready to go I have no problem. I don't want to mess up my transmission doing this all the time. I thought it might be the mass air flow or the injector but both parts are very expensive so if anyone has had a similar problem or had to do this before PLEASE give me some advice!!!
1997 Blazer 4.3L V6
Old Aug 19, 2012 | 06:43 PM
Does the check engine light come on with the bulb check and then turn off?
Is the check engine light on or flashing while driving?
If so, What DTC's are in memory?
Check fuel pressure and leakdown and post the results.
Did you use AC Delco plugs, wires, cap & rotor & fuel pump?
Does the transmission shift properly?
Are there any electrical "issues" or "gremlins" with the vehicle, (possible faulty ignition switch, very common with 1997)?
Old Aug 19, 2012 | 08:16 PM
jjmatacia@aol.com's Avatar
jjmatacia@aol.com is on a distinguished road
I had the same problem changed fuel pump and spider injectors problem solved
pensfan74
14
Sep 17, 2013 10:26 PM
Coinhunter
Jul 7, 2013 08:21 PM
mikepro
Aug 15, 2011 07:03 PM
greg94
20
Aug 31, 2010 12:57 AM
kwikshifter
Jul 16, 2010 01:35 AM
