old school rad fit?
I don't know. How I research this problem is to look up both the 91 and the 99 S-10 models in a net catalog like Rock Auto and look at the same rad. with the same options and then compare the two part numbers. If they are the same part nos , then yes, they should swap. Don't forget the Engine oil cooler and the trans cooler---you must have the same coolers and the same fittings on both for the swap to work !
