out of things to replace
Old 03-18-2013, 08:48 PM
puzzled's Avatar
puzzled is an unknown quantity at this point
p0101 first then p0300 then o2 senser that came up because on the first day i cut the pipe infront uf the cat that has not come back on since i weld it back to gether tonite
  #32
Old 03-18-2013, 09:06 PM
Did you clear the codes and drive it after welding the pipe?
  #33
Old 03-18-2013, 09:09 PM
puzzled's Avatar
yes codes were cleared
  #34
Old 03-18-2013, 09:13 PM
ok. Does your scan tool allow you to view fuel trim? Should be a menu showing "Short term fuel trim" and "Long term fuel trim" or possibly STFTB1, STFTB2, LTFTB1 & LTFTB2.
  #35
Old 03-19-2013, 04:23 PM
puzzled's Avatar
no this one does not
  #36
Old 03-19-2013, 04:29 PM
P0101 is a mass air flow sensor or circuit problem. Any chance you have a K&N air filter on it? If so, the oil on the filter may have contaminated the elements in the MAF sensor. Whether you do or don't have a K&N filter, remove the sensor and clean the elements with brake clean spray, (it leaves no residue). Be very careful not to disturb the elements, they are very fragile.
  #37
Old 03-19-2013, 04:43 PM
puzzled's Avatar
i see on here people talking about spark plugs when i changed my plugs they were out of ac delcos so they gave me bocsh
and no k&n filter
  #38
Old 03-19-2013, 04:53 PM
puzzled's Avatar
going to the parts store to get correct plugs and brake cleaner
  #39
Old 03-19-2013, 04:58 PM
AC Delco 41-993 with a gap of .060"
  #40
Old 03-20-2013, 03:00 PM
puzzled's Avatar
Pulled plugs to replace and cylinders 1 3 5 hav e oil on them
Quick Reply: out of things to replace
