out of things to replace
Old 03-20-2013, 03:02 PM
puzzled's Avatar
puzzled is an unknown quantity at this point
No oil in antifreeze or vice versa
  #42
Old 03-20-2013, 03:37 PM
Uh oh, not good. Better pull the rocker arm covers off. You'll probably find clogged oil return passages. Inoperative PCV system or lack of regular oil changes may have something to do with it.
  #43
Old 03-20-2013, 03:40 PM
puzzled's Avatar
but this truck doesn't burn or smoke it all
  #44
Old 03-20-2013, 04:49 PM
If the plugs have oil on them, it's burning oil. You may not see it out the tail pipe...yet, but it's burning oil
Edit: If the oil returns are restricted, the oil can rise above the valve stem seals, run down the valve stem and into the combustion chamber where the spark plug burns it off. Either that or you have piston ring or valve stem seal problems only on one bank... not likely.
  #45
Old 03-20-2013, 06:36 PM
puzzled's Avatar
ok heres the new deal this is my wife truck and since i wasnt gettin it fixed rite away she call her dad in and he pulled the plugs and said it was oil but it wasnt and it was on the passenger side they were just wet and the driver side was dry but full of carbon i started it today and held the rpms at 3000 they held for a bit but then dropped i reaaly think it is a pump going bad so this weekend i will replace the pump. it just so happens i have a brand new one in the box since i own 5 of these trucks / blazers i will repost if this does not work but i think captain hook you r correct to chase a fuel problem first
  #46
Old 03-24-2013, 12:08 PM
puzzled's Avatar
so after a long saturday and half of today replacing fuel pump twice checked spider injector and in the process dropped a 10 mm nut down the intake so had to do a whole intake job got everything back together and im still having the same problem this has got to be an electrical problem
  #47
Old 03-24-2013, 12:29 PM
cw801971's Avatar
cw801971 is on a distinguished road
How does the EGR valve look? If it is open constant it could be part of your problem. I've run into issues with them in the past. But they show up at an idle as well as when running.
  #48
Old 03-24-2013, 01:26 PM
puzzled's Avatar
it stumbles when idle
  #49
Old 03-24-2013, 04:50 PM
puzzled's Avatar
all cylinders r at 120 psi
  #50
Old 03-24-2013, 08:09 PM
racechaplain's Avatar
racechaplain is on a distinguished road
Did you actually pull the valve covers like the captain suggested? It could still be clogged oil passages. I'm having the same issue and have replaced everything possible other than the crank sensor and the speed sensor. Before I spend anymore money, I'm also trying to diagnose the issue. This surging thing sucks! I feel your pain! Mine idles fine until it reaches operating temp. I'm also wondering if it could be a ecm issue at this point. Those are my rabbit trails...
username772
11-14-2013 01:03 PM
nepa zr2
02-17-2012 09:32 PM
travisrussell88
10-20-2011 10:16 PM
91_4_Door
03-19-2006 01:37 PM
blazin97
06-30-2005 11:03 PM
Quick Reply: out of things to replace
