P0128 Help
Old 03-02-2011 | 02:49 PM
kameronatm10's Avatar
kameronatm10 is on a distinguished road
Where is the thermostat located on the 01 Blazer?
Old 03-02-2011 | 05:49 PM
jbsnowboarder16's Avatar
jbsnowboarder16 is on a distinguished road
Its located on top of the engine in front of the intake. The housing that you remove to access it is black (at least on my 2000 it is). You have to drain a little (About 2 quarts) antifreeze out of the radiator so you don't spill it when you remove the housing. To get to the housing bolts, I found that removing the throttle cable brackets made it a lot simpler since they are in the way. Once you remove those, it is as simple as removing the housing, removing the old thermostat, putting in the new thermostat, making sure the housing surfaces are clean and then repeat the process backwards.
I was surprised there was no gasket for the housing, but I guess the rubber ring on the thermostat acts as the gasket.
Old 03-09-2011 | 03:05 PM
If I just replaced the thermostat, how long should it take for the "Service Engine Soon" light to turn off?
Old 03-09-2011 | 03:27 PM
Ryanmatt135's Avatar
Ryanmatt135 is an unknown quantity at this point
if you replace the thermostat, and top off the coolant level, i would drive it to see if the temp rises to normal opperating temp, if it does you can clear the code by taking the negetive battery cable off and reinstalling it.
Old 03-09-2011 | 03:59 PM
I already brought the car up to operating temperature with no issue. Removing the negative terminal will reset the codes?
Old 03-09-2011 | 05:14 PM
yea, unhooking the battery will reset the Computer.
AKYooper
12-27-2013 01:51 PM
bulwaagh
10-11-2012 02:39 PM
tyla721
01-09-2008 01:35 PM
hoffy
10-26-2007 02:31 PM
Quick Reply: P0128 Help
