P0137 came on today...
Old Aug 1, 2007 | 09:48 PM
drperry's Avatar
Default P0137 came on today...
They Haynes manual says it's the "Downstream Heated O2 Sensor Circuit low voltage"
Is that the O2 sensor after the cat? If it is, I won't worry about it for awhile, as it shouldn't hurt my mileage much... But since I'm leaving on a trip tomorrow after work, I'm going to need all the gas mileage I can get, so if it's not the one after the cat, I'll try and convince the dealership to fix it tomorrow... Help/advice/ideas welcome!
Old Aug 2, 2007 | 06:40 AM
Default RE: P0137 came on today...
P0137 - HO2S Circuit Low Voltage B1S2
Yeah, that is the post cat sensor on 98+ trucks with 3 sensors. If this code were to pop up on '96-'97 trucks, this would be the down stream sensor directly ahead of the catalytic converter.
This will have no impact on fuel mileage if the sensor itself is going bad. I recommend clearing the code and seeing if it pops back up.
Old Aug 2, 2007 | 02:52 PM
drperry's Avatar
Yep, that's what I did.
Hopefully it clears itself up in a few days... My truck was running on 5 cylinders for awhile so the extra output from the cat might be fouling it up...
But that's what I needed to know! Thank you very much! Now I can go on my trip and not worry!
Old Aug 27, 2007 | 03:18 PM
drperry's Avatar
Well, the code still randomly comes on and off, so I'm guessing my sensor is buggered, lol.
Unless there's still excess junk being thrown out the cat... Which shouldn't be, since it's been awhile...
Would a buggered cat trip up the sensor?
Old Aug 27, 2007 | 03:38 PM
Probably means that the sensor is in fact bad.
Old Aug 27, 2007 | 04:08 PM
drperry's Avatar
Understandable, I suppose, considering that it's been totally submerged, probably had a large amount of junk from 8000 missfires pass by...
Old Nov 17, 2007 | 07:43 AM
drperry's Avatar
Update: Apparently changing the spark plugs fixed the problem... I haven't had the SES light come on, or seen this code come through yet...
Unless I haven't done the right number of drive cycles for it to pop up...
mdehoogh
Headers, Intake, & Exhaust
Nov 20, 2007 10:53 AM
jagblazer01
Jun 7, 2007 07:13 AM
minijosh
Sep 20, 2006 10:20 AM
TTA89
Engine & Internal
Nov 30, 2005 03:47 PM
V6 Vortec Jimmy
Sep 2, 2005 01:12 AM
