P0141B troubles
Old Mar 16, 2012 | 12:37 PM
ccross13126's Avatar
ccross13126 is on a distinguished road
Default P0141B troubles
I have a 2001 blazer 4wd. which shows code P0141B. It has 3 sensors- 1 in the left bank pipe, one in the rt. bank pipe, and 1 after the converter. I replaced the 2nd bank sensor (with a Bosch- everyones favorite not to use). I checked the wiring- I have 12 volts at the pink wire, ground on the brown. I didn't check the purple or tan wires as I wasn't sure what to look for at these wires and didn't want to short or burn something out. Can anyone help me with this problem before I go "nutser" than I am already. I'm in NY and my 10 day temporary inspection is about expired. I originally replaced the sensor, cleared the code with a scanner and had to drive 150 miles with no code displayed before I could get it inspected. Just as the trip odometer turned 150 miles, P0141B poped up. Short of a large stick of dynamite how do I fix this?? Thanks!
Old Mar 16, 2012 | 01:09 PM
pettyfog's Avatar
P0141 is a heater circuit fail in Bank 1 Sensor 2 That means second sensor in line of exhaust flow. counting from the driver's side. If you have 3 sensors, then it's after the cat. If you have 4, then it would be the one before the cat. There is no bank 2 sensor 2
I have no idea what the B means. So I hope you kept the old O2. Pull the Bosch from pass side and put back the old, checking for 12v, then same after the cat and install the bosch.
Kellogg
Jan 31, 2010 04:28 PM
jaybird33081
Jan 4, 2010 11:19 PM
baja457
Oct 28, 2007 08:21 AM
getonerd
Sep 28, 2007 07:20 PM
2blzers
May 13, 2007 09:09 PM
