P0410 - Secondary Air Injection Malfunction ?
My "Service Engine Soon" light is on and won't go away. I took my 2001 4.3L Blazer to the local Auto parts store to check the code - (P0410 - Secondary Air Injection Malfunction), the code was reset and for five minutes it was gone. Does anyone know what would cause this code ? What parts need to be replaced ? Please Help, orange light very annoying.
RE: P0410 - Secondary Air Injection Malfunction ?
Have a read through some of the threads linked to below in the 'Related Threads' list. Sometimes you can dismantle the air injection pump and clean it up. Most often, you have to replace the pump and intake hose. The original intake hose is quite short and can allow water into the pump. Cold weather and water in a confined space is a bad combination. A small amount of water will just lock up the pump. Larger amounts will break things.
On a 4wd truck, the pump is located under the radiator along the passenger side frame rail. I'm not positive if this is the location for the pump on a 2wd truck.
Swart I have the same good and my blazer will not start could this be my problem? I have found that your very knowedgeable on s10's I just posted another post. as it has gotten colder my blazer would start and stall then start right up and run fine now it will not start thanks for your help. Rob
rob, I'll reply to your other thread. No need to pull this one off topic.
jb34r5e
10-08-2014 08:10 PM
mmmrodge
11-19-2012 12:06 PM
Chevy33
02-24-2012 09:34 AM
priesman64
04-15-2011 11:42 PM
stormshadow1
07-11-2009 10:13 PM
