P1628 ECT Pull-Up Resistor?
Old Feb 13, 2010 | 03:04 PM
Rottidog's Avatar
Default P1628 ECT Pull-Up Resistor?
Last night I had to reset the comp. for the taller tires & to do that the scanner has to check/clear DTC's. Well it had 2,
- a P0128 Coolant Thermostat (Coolant Temperature Below Thermostat Regulating Temperature)
- P1628 ECT Pull-Up Resistor <--- wth is that & any ideas on what steps to take to correct these?
Old Feb 16, 2010 | 02:39 AM
awe341's Avatar
awe341 is on a distinguished road
The first code tells you that the computer is reading a low coolant temperature from the coolant temperature sensor.
The second code is telling you that a fault has been detected in the coolant temp sensor itself.
If you replace your faulty coolant temp sensor you should not get either of those codes again.
Old Feb 16, 2010 | 12:06 PM
Rottidog's Avatar
Right on, thnx Awe... the truck is at the shop right now getting the rear shackles installed & cat back dual exhaust, so i called him & told him to replace the engine coolent temp. sensor.
The P0128 has been coming up a lot & that makes sense that the ECT sensor is messed up causing that 128 code
Old Feb 21, 2010 | 05:16 PM
Rottidog's Avatar
Yup, that took care of it, i hope
it's running at the proper rpm's when it's cold & as it warms up... as a bonus, somehow my oil pressure sending unit was maxing out the guage, now it works, hmmm it might have to see an exorcist lol
thnx again
Blazers.B.Kewl
Apr 22, 2013 10:06 AM
KevT
Sep 8, 2012 02:05 PM
Smoked
Oct 31, 2008 03:07 AM
dickleon
Jun 30, 2007 05:57 PM
Chevyguy032
Mar 16, 2007 02:33 PM
