Passlock
Old Sep 23, 2011 | 07:17 PM
J_man01's Avatar
J_man01 is an unknown quantity at this point
Default Passlock
Ok I've finally had it with my blazer and this stupid passlock. I've changed everything the pcm the bcm the ign switch the multifunction switch and I'm still having a no start situation once and a while with it. I've done the relearn thousands of times and it helps for a day. How the hell do I eliminate the passlock? Theres gotta be a way to eliminate it.
Old Sep 23, 2011 | 07:46 PM
bromanjr's Avatar
bromanjr is on a distinguished road
[quote=J_man01;462259]Ok I've finally had it with my blazer and this stupid passlock. I've changed everything the pcm the bcm the ign switch the multifunction switch and I'm still having a no start situation once and a while with it. I've done the relearn thousands of times and it helps for a day. How the hell do I eliminate the passlock? Theres gotta be a way to eliminate it.[/quote
What about the Passlock Sensor at the Key? It senses the turning of the key and sends the signal to the BCM. Sometimes the wiring (3-wires, Yel, Org/Blk, Red/Wht) gets damaged or the sensor fails.
Old Sep 23, 2011 | 08:02 PM
J_man01's Avatar
Isnt that part of the ign switch?
Old Sep 23, 2011 | 09:13 PM
bromanjr's Avatar
According to Mitchell, the Passlock sensor is "At Ignition Switch, Part of Lock Module" Look for the (3) small wires.
You should check for Passlock "B" Codes.
Old Oct 4, 2011 | 04:31 PM
J_man01's Avatar
Im getting no b codes The 3 wires were part if the ign switch the module is what the 3 wires plug into correct?
Old Oct 4, 2011 | 06:37 PM
bromanjr's Avatar
B codes won't read on the simpler OBDII readers. You need a mid to high end reader to be sure there are no B codes.
The 3-wire harness is the one.
Old Oct 4, 2011 | 07:58 PM
Mike98Blazer's Avatar
If you have decided you HAVE to have passlock disabled i believe PCM4Less will do it as part of a tune.... beyond that I'm not sure. But it CAN be done.
Old Oct 4, 2011 | 10:10 PM
vegie_2's Avatar
vegie_2 is on a distinguished road
Replace lock cylinder and keys, I did that on our 02 impala and it works every time now
Just have to do the relearn long procedure.
This is not the ignition switch it's the key cylinder
Old Oct 14, 2011 | 02:06 PM
J_man01's Avatar
I'm geting no bcodes ive got a scanner that will read them. I replaced the passlock sensor again it working fine for now so im getting rid of it before this crap happens again out of all the blazers and s-10 trucks ive owned this one by far has been the biggest POS. Thanks for all the help guys.
eknox327
25
Dec 13, 2018 11:33 PM
knight1292
Aug 14, 2008 09:30 AM
blkblazer
Jun 27, 2008 04:47 PM
phantom
Mar 18, 2008 02:10 PM
WolfPack
Nov 13, 2007 09:37 PM
