Passlock
Ok I've finally had it with my blazer and this stupid passlock. I've changed everything the pcm the bcm the ign switch the multifunction switch and I'm still having a no start situation once and a while with it. I've done the relearn thousands of times and it helps for a day. How the hell do I eliminate the passlock? Theres gotta be a way to eliminate it.
[quote=J_man01;462259]Ok I've finally had it with my blazer and this stupid passlock. I've changed everything the pcm the bcm the ign switch the multifunction switch and I'm still having a no start situation once and a while with it. I've done the relearn thousands of times and it helps for a day. How the hell do I eliminate the passlock? Theres gotta be a way to eliminate it.[/quote
What about the Passlock Sensor at the Key? It senses the turning of the key and sends the signal to the BCM. Sometimes the wiring (3-wires, Yel, Org/Blk, Red/Wht) gets damaged or the sensor fails.
I'm geting no bcodes ive got a scanner that will read them. I replaced the passlock sensor again it working fine for now so im getting rid of it before this crap happens again out of all the blazers and s-10 trucks ive owned this one by far has been the biggest POS. Thanks for all the help guys.
eknox327
25
Dec 13, 2018 11:33 PM
knight1292
Aug 14, 2008 09:30 AM
